10-11-2007 09:04 AM
10-11-2007 10:53 AM
Hey Eric,
I'm trying to figure out why you need the modelsupport2.dll for your user interface? The modelsupport2.dll is primarily used for the process models that ship wtih TestStand. I'm not aware of much documentation on the modelsupport2.dll but you are correct in assuming you do have the source code for it.
I assume that when you say program you are talking about your custom process model? If so then you can simply make function calls to the modelsupport2.dll the same way they do in the default process models. All of this is located in C:\Program Files\National Instruments\TestStand 4.0\Components\NI\Models\TestStandModels I recommend copying everything from the C:\Program Files\National Instruments\TestStand 4.0\Components\NI to the C:\Program Files\National Instruments\TestStand 4.0\Components\User folder and working from that one. If you didn't know already then the way TestStand works is it looks in the User folder first and if it doesn't find it there then it goes to the NI folder. You'll see this hierarchy scattered through the TS folder. The reason they do this is so that customizations can go in the User folder and then you still have all the native stuff in the NI folder.
Even though the modelsupport2.dll was written in CVI you can still call it from wherever you want. A CVI runtime engine is installed on your machine when you install TS. This is necessary because otherwise the process model wouldn't run. Therefore you are able to use the modelsupport2.dll from any language. If you want to customize it then you have to have an ANSI C editor and compiler. Of LabVIEW is your choice of programming language then you can create your own dlls, vis, whatever and call those from your process model using the LabVIEW adapter.
I guess it really comes down to understanding what you want and how to get there. The user interface does not use the modelsupport2.dll. It simply calls into the TestStand engine and executes your sequences by calling the process model. When you are developing your user interface are you editing one located here: C:\Program Files\National Instruments\TestStand 4.0\UserInterfaces\NI Again you should copy to the User folder and edit the one in the User folder.
Hope this helps. Please let me know if I am not on the right path.
10-11-2007 02:08 PM
Sam,
I understand how the user interface works and how TestStand works. What I wish to do is incorporate much of the functionality of the modelsupport2.dll into my custom user interface written with LabVIEW. The dll cleanly handles multiple threads for a parallel model starting, stopping, terminating, entering new Serial Numbers for UTTs, etc. I wish to be careful writing my code to imitate these functions. Not handling these threads correctly could lead to unexpected results.
I hope this gives you a better understanding of my request.
Eric
10-11-2007 04:18 PM
10-11-2007 04:50 PM
10-11-2007 10:24 PM
10-12-2007 07:43 AM
EJS,
I understand what you are trying to do. I have took the same path in making an OI for the parallel process model with only two test sockets running.
The thing I wanted (and I think you want the same) was the modelsupport2.dll dialog popup for executing a parallel execution is a bit inconvenient that it is not part of the OI. I also wanted a window that traced multiple executions at the same time. The modelsupport dialog only give a basic status and you had to go to the OI and switch between executions to see the tracing.
What I did was to disable the modelsupport calls all together an made a custom OI with two exection view managers.
The task was not simple. I also had the UUT serial number entry as part of the OI. That lead to challenges in getting the serial number from OI to the running sequence in the test socket.
I also had the same concerns as dowNow, in that I didn't want to require my sequence to only be compatible with this OI. What I did there was create a UI message that would return a made up "OI Version" string. This return value would only exist in my OI. If it didn't detect my OI then I ran with the default modelsupport2.dll dialog.
I have considered creating a scalable version of a parallel OI but I will probably never get around to it unless my company needs one.
In this thread I posted a version of the two socket OI I once created. You can also get a description of how it worked by reading the thread.
Paul
10-12-2007 09:43 AM
10-17-2007 09:02 AM
Paul,
You have a lot of good ideas. I am relooking at what I wish to accomplish and what is really necessary from the user interface. I believe I can simplify my request.
For my parallel model, can someone show me how to initiate each of my 4 sockets individually and terminate them individually from within my operator interface. I will handle SN entry, stopping and starting tests, etc. through local variables. Once the socket terminates, that socket will restart, requesting a new SN.
All 4 sockets will remain independent until I enter a Terminate all and Exit. These I know how to do.
Thanks for your help.
EJS
03-09-2017 01:23 PM
I know this is an old thread, but it's the one I found while trying to do the same thing as the original poster. in TestStand 2014 the above suggestions are overly complicated.
Based on some unit tests I did this is all you need to do:
There are other things you can set or get but this seems to be the minimum
