07-15-2013 04:48 AM
After completing a project with teststand, we want to strip down the project from all project specifics down to a default project to start with.
How can the project file (.tpj) be renamed? When browsing in the workspace and selecting the project, you can choose to rename the project (see attachment workspace.jpg). But the .tpj on the disk isn't changed at all. We want to rename it to XXX_PTS.tpj. Also in the Workspace Object Properties Dialog Box, in the General Tab, the Path Name isn't editable and has still the old name (see attachment properties.jpg).
Renaming the .prj in Windows isn't doing the trick. Teststand will ask for the old file.
What are the correct steps to rename the .prj file?
07-15-2013 08:19 AM
Here's what I would do in your situation:
Remove it from the Workspace
Rename it in Windows
Add it to the Workspace with the new name
Does that work for you?
07-15-2013 11:47 AM
Yes, this works. Thanks.
