02-03-2014 09:50 AM
I have two applications installer deployed with Teststand Deployment (TSD). Both have the same installation folder. The issue i have when i execute them is : the uninst.exe is being override with the last installation. So, when I try to uninstall the applications from the control panel, I can uninstall just one application. The second says, it is already uninstalled..Then I have issues to reinstall it.
I was looking for an option to rename the uninst.exe or modify its path. Do you know how i could do that ?
Thanks in advance,
02-04-2014 02:22 AM
You can run custom commands to execute any command http://zone.ni.com/reference/en-XX/help/370052K-01/tsref/infotopics/db_custom_commands/
However, if you rename or move the uninst.exe Add/Remove programs will no longer be able to uninstall it for obvious reasons. More details here: http://community.spiceworks.com/how_to/show/2238-how-add-remove-programs-works
Can you install it to two different subfolders within the main installation directory?
02-04-2014 10:07 AM
Do you have to put both applications in the exact same location? You could create a subdirectory for each of your applications to avoid the problem.
02-04-2014 10:40 AM
Hey Redzouz,
To help us figure out why this is happening, could you provide us with a bit of background information about how this happened? For example, did you create one deployment, save the TSD and then copy it on your machine to generate the second deployment TSD, or were these two completely independent deployments?
I'm also curious as to whether these applications need to be in the same folder or not. As mentioned previously, are you able to put them in subfolders of the main directory, or is something preventing you from doing that?
Looking forward to hearing back from you.
