Hi Dave,
I take it you are using the old style Teststand Operator Interface.
The only way would be to modify the code in the exedisp.c, in UpdateOnStepChange() function. Just comment out the SetCtrlBitmap() function there are two calls in this function.
As to whether it is going to make a noticable different in performance, well that depends on the spec of the controller (PC), graphics card etc. you are using. But you probably wouldn't notice any diference.
Before you make any changes, copy the sub-folders from the NI folder to the User folder and work from the User folder.
Regards
Ray Farmer
Message Edited by Ray Farmer on 05-07-2005 06:29 PM
Regards
Ray Farmer
