I've modified the default stylesheet to remove a lot of the fluff added in the test report. However, I'm stuck trying to remove the subsequence headings from the report. Can anyone with stylesheet experience give me some advice?
I can't modify TestStand reporting at all, only the stylesheet.
I've attached a picure which hopefully should help expain the problem.
-Jeremy
