12-15-2010 01:01 AM
While building the EXE for the Fully Featured OI (LabVIEW), I enabled the Remote debugging option (Enable Debugging and Wait for Degugger to Launch). I tested running it some remote PC and it is running good. I connected this remote EXE to my computer, everything is loaded and the Block diagram is visble, but I got a Error while running the EXE (attached as an Image). Is there any problem with then ActiveX when called Remotely ? Please tell me what should be done to make the remote debugging possible.
This happens to my customized OI also,
Thanksm
AshwiN,
02-04-2011 07:48 PM
Are you using TS remote EXE server?
