08-14-2006 08:12 PM
08-15-2006 12:37 AM
Does the error messages point to what is not being release?
You need to look through your code and find out where you haven't used a closed reference VI. The only reference you dont what to close is the one you pass via the connector pane of the VI. Any reference you create within your code you should release before returning.
If its in your TestStand sequence then set the reference variable to Nothing eg MyObjRef = Nothing.
Regards
Ray Farmer
08-15-2006 12:03 PM - edited 08-15-2006 12:03 PM
Message Edited by Nick C on 08-15-2006 01:39 PM
