Thanks for reply...
The variables i'm using are numeric ,so i had created
"Number"datatype.My application is that i had written a Teststand(TS)
Script(set of commands) where i will be providing different values to a
particular variable in different steps of sequence.This varible is
passed to a LABVIEW(LV) program where it reads continuously and for
data handling from TS to LV where i'm using ActiveX property
continuously in loop.
Just i wanted to know if there are any other better ways to handle
this..as variable updation is done through Stationglobals of TS and
Activex in LV..Data updation may not happen sometimes at the desired
instant of time..
One more question is that.. Is there any specified inter-step delay in
TS(the reason for this question is..my application is time critical(a
loop is expected to run at every 10 ms) and if such say any of kind of
delay is there,then it may affect my application..
Cheers
Murralidaran
