12-21-2005 03:50 AM
Hi I’m developing a test stand sequence fie for my tester. In that I’m using NI DMM 4060.
I want to programme Test stand to read the DMM range and function from Text file.
I need to measure voltage, current and continuity from one sequence file.
Can any body suggest me how I can do this.
Your help in this regard is appreciated.
Narendra
12-21-2005 03:02 PM
Narendra
12-22-2005 12:34 AM
You could use the PropertyLoader step to load your DMM function and range information into into a Locals variables.
Or
You could create a custom step which have the required Step properties. Then you can use the PropertyLoader to load directly to your step properties, similar to loading the limits of a step.
Or
You could make use of the IVI step types.
Regards
Ray Farmer
12-22-2005 02:05 AM
Hi Ray Farmer,
Thanks for you help. I’m able to load limits from text file but I’m facing trouble while loading the variable and the variables are not passing to my calling programme (i.e. my Labview DMM driver) can you please help me by sending any example programme how to pass variables to calling programme.
Thanks & regards.
Narendra
12-22-2005 08:59 AM
