NI Home
Cart Cart | Help
You are here:
Reply
Member
Paulus56
Accepted Solution
Read command line arguments with an ActiveX step
Hi
I would like to read the command line parameters from TestStand startup. I did find an ActiveX resulting in a Object Reference (See Locals.CommandsRef). How do I use this reference to really get the arguments and their count? See also screenshot.
Active Participant
ThiCop
Re: Read command line arguments with an ActiveX step
Hello Paulus,
It's possible to access command line arguments in the following (pseudo-code) way:
Locals.AppMgrRef = RunState.Engine.GetInternalOption(InternalOption_ApplicationManager);
Locals.CommandsRef = Locals.AppMgrRef.CommandLineArguments;
Locals.CountNum = Locals.CommandRef.Count;
For i=0 to Locals.CountNum - 1
    Locals.CommandString = Locals.CommandRef.Item(i);
End
Do you want to use it with the actual TestStand Startup or rather with the start-up of a sequence file?
Kind Regards,
Thierry C - Platinum Applications Engineer - NI Belgium
CLD
If someone helped you, let them know. Mark as solved and/or give a kudo. :smileywink:
Member
Paulus56
Hoi Thierry,
Thanks for the help. To start with the easyiest part: I would like to know the arguments of the starting sequence file.
Ik saw this pseudocode before but don't know what to do with it. I would like to read the arguments in TestStand. Where do I put this pseudocode? It makes no sense putting it in a TS-statement.
I tried to use ActiveX as seen in the sscreenshot. Is that a wrong direction? If correct, how should I go on with this Object reference.
Active Participant
BasvanDijke
Hi Paulus,
Via this link, you find an forumthread that describes the same issue. testStand does not support this, but there is a workaround. Attached you find the code.
The attachment includes a LV vi with the command line. If you doen't use Labview, here is the command line:
C:\Program Files (x86)\National Instruments\TestStand 2012\Bin\SeqEdit.exe /goto "Parameter1 = test" /runEntryPoint "Test UUTs" D:\Testsequence.seq
Bas
Member
Paulus56
Thanks for the solution. This works.
Active Participant
ThiCop
Hello Bas,
Thanks for helping during my absence (giving courses)!
I'll give you a kudo too.. :smileywink:
Kind Regards,
CLD
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
