02-16-2007 01:23 PM
03-20-2007 04:48 AM
Hi Lars,
Which examples did you look at, and what is the reason you cannot adapt these in your application?
If using the development environment in Teststand, you can use the Thread ring control (drop-down box) to access all of the threads that are currently executing. If you use a breakpoint, you can access the threads by using the ring control in the top-right of the execution window. This way you can look at the code in the thread and step through it.
