01-03-2006 04:31 AM
01-04-2006 12:17 PM
01-04-2006 02:26 PM
Rafi,
I think there are two different posts in the forum about this issue.
Tyler is right. You have to load the sequence file before setting the sequence file global values.
Using the "<All Sequences>" tag in order to set a File Global variable does not make any sense though.
The File Global variable will be available for all the sequences in the sequence file scope all the time.
Once you set the File Global variable at the beginning (after you load the sequence file) all the sequences should be able to access it.
The "<All Sequences>" tag is intended to set all the existing variables present in the different sequences in the specified sequence file.
For example it could be used to set the high and low limits for an specific numeric limit step present in all the sequences.
Remember that you can also load properties for an external sequence file using the property loader.
It would be great if you could attach a simple sequence file in order to understand the problem you are trying to solve.
Best Regards.
Antonio Lie.
