05-26-2010 02:16 PM
I am looking for an example of using the property loader step to load a labView type array of strings.
Not much in the reference manual...
thanks,
jvh
Solved! Go to Solution.
05-27-2010 11:50 AM
The best way seems to be to export it first.
On the variables pane I created a local array of strings and populated the values while at it.
Then Tools>Import/Export Properties - Source/Dest tab, set data location to file and browsed in a file name. I used tab delimited for Format so I could just type a string per line w/ no qoutes. On properties tab selected the Local array I created. Then hit Export and the file was created. Opened the file, copied and pasted for other cases, and changed markers accordingly.
Thanks go to Chris at NI-Austin.
