03-24-2015 09:21 PM
Is it possible? I don't see a command type or an API for it.
03-25-2015 01:08 PM
Hi jsiegel,
It depends on what you want to do with the user manager. There are a number of API calls that will allow you to create and manage users. Take a look at some of the following documentation:
http://digital.ni.com/public.nsf/allkb/563B5DDFA5014A0886256F880018D1FB?OpenDocument
http://www.ni.com/pdf/manuals/372844b.pdf
03-25-2015 01:20 PM
I think the user manager is built into the sequence editor and cannot be detached. I'm sure it is just calling into the API.
http://digital.ni.com/public.nsf/allkb/8DFDCC6D8C0DEFB08625799F0074B616
That link should get you on the right track. Forgive me if it is the same one Kristen showed.
03-25-2015 02:19 PM
I know I can use the API to recreate my own user manager (to add/edit/delete users), but I would rather use the entire user manager UI that is already complete and working! But I think jigg confirmed my suspicions that this is not possible. I guess I have to go reinvent the wheel! Thanks.
Jeff
09-12-2016 05:59 AM
Hi Jeff,
How is reinventing the wheel going? Could you share some code?
BTW I think that NI should support creation of custom User Manager because it is pointless to deploy custom UI without possibility to manage users in it...
09-27-2016 12:39 PM
Michał,
Sorry, I did not create my own custom user manager because the feature was not important enough to spend time on.
