Hi Chris,
I am attaching a simple example.
I am changing the names of the multiple numeric limit test measurements dynamically.
I am using the TestStand API to accomplish this. I am using the ActiveX Adapter to access the API methods and properties within the same sequence but you can use the same methods and properties in a separate sequence or in your code module.
If you have any questions let me know.
The attached sequence file is a TS 3.1 sequence file.
Hope It helps.
