i use TestStand 3.0 and the Agilent E3643A DC power supply. If i use the IVI driver in TestStand (functions like configure or initiate or ...) i get a beep and one of the following error messages: (!!!But the instructions are executed successfully!!!!)
-103 Invalid separator
An invalid separator was found in the command string. You may have used a
comma instead of a colon, semicolon, or blank space - or you may have used
a blank space instead of a comma.
Example: TRIG:SOUR,BUS or APPL 1.0 1.0
-113 Undefined header
A command was received that is not valid for this power supply. You may have
misspelled the command or it may not be a valid command. If you are using
the short form of the command, remember that it may contain up to four letters.
Example: TRIGG:DEL 3
(from the Agilent E3643A DC power supply data sheet)
I have installed the actual IVI driver from the NI device driver network. I use COM1 with following settings: 9600/8/None/2/DTR/DSR.
Is there something wrong with driver, the settings in MAX or with Hardware (Firmware?).
Thank you
Kai Schwekendiek
