I am using Testand 3.2
Most of my tests have a single result value.
However, Some require more than one result value (i.e two).
I would like to specify a "multiple result test step", and assign limits to each result.
So far I can only find silly solutions to this problem:
1. Feed in teststand reference into my test.
2. Use active X !??
3. Create custom local variable array and then test each result in post tests..
The above solutions are dumb.
Can someone provide a proper solution to creating a test step with multiple results.
Thank you.
