11-23-2006 07:02 PM
11-24-2006 12:38 AM
Are you expecting the new values from your configuration files to be stored in the FileGlobals after you sequence has stopped executing?
If you are, then you are only changing the runtime version of the fileglobals.
You have to place them in the FileGlobalDefaults. Then set the change Increment to indicate that the sequencefile has changed.
Regards
Ray Farmer
11-26-2006 08:49 PM
11-27-2006 03:17 PM
11-27-2006 04:04 PM
11-27-2006 10:37 PM
Hi, Sam,
Thank you for your guidance.
I tried your suggestion, but am still not able to make it work. Checking your suggested procedure, I feel that maybe I did not put right parameters for the method call in your step 9. I am attaching the sequence I modified, and am wondering if you have any idea about what is wrong with it. I got the error message "the item name ip1 is invalid, because it is already in use" when runing the sequence.
To be honest, I am not sure if I understand the NewSubProperty. Do you know if there is any example for me to read? That would help me a lot to understand how to use NewSubProperty.
Also, you mentioned that "Then in the next step you can assign it to a value". How do I assign a value to it? Something like, FileGlobals.lookupString = Locals.Scripts_INIFILE?
Xuedong
11-27-2006 10:45 PM
Hi, Ray,
Thank you again for your help.
I do feel that I am lack of the knowledge for API/PropertyObject kind of things, after reading your suggestions. Let me study a little bit and see if I can follow what you suggested.
Xuedong
11-28-2006 09:12 AM
Thanks for keeping me honest Ray.
I misread the question. I've attached your sequence with what I believe you are looking for.
Basically I call an activex step like Ray described above that will allow you to select your variable dynamically.
11-28-2006 10:17 AM
Hi, Sam,
I am eager to read your attached file, but I can not. I got error message. I am using TS 3.1, which is incompatible with TS 3.5. Is there any way to allow me to read your sequence?
Xuedong
11-28-2006 12:08 PM
Sorry Xuedong,
Here are two images that show what I did. Basically there is an ActiveX step in the loop that and then I show the specify module for that activex step.
