09-29-2006 03:03 AM
10-02-2006 03:30 PM
If you had just one of your ver8.x steptypes in a sequencefile, you get the same affect, ie, first time loaded and run the panel is active, the second time etc, you have to click on the panel to make it active. So it doesn't matter if you mix your RTE versions.
I set the Show Front panel when called in the Specify Module dialog. Now the VI is active when displayed all the time.
Why the difference between Ver7.0 and Ver8.x, I dont know, but its probably a good idea to set this setting either in the Specify Module dialog or in the VI properties, if its a Modal type dialog you are after.
Regards
Ray Farmer
10-03-2006 03:15 AM
10-03-2006 03:46 AM
10-04-2006 11:42 AM
The issue discribed by Julien is also visible with the example provided with TestStand :
<TestStand>\Examples\ModalDialogs\LabVIEW\LabVIEWModalDialog.seq
Using LV8.0 or above, the dialog box is not active when it appears (which is a strange behaviour for a modal dialog box) !
Something has changed between LV7.1 and LV8.0...
Also, when using the TestStand - Start Modal Dialog.vi, the specify module option "Show VI front panel when called" is not supposed to be checked. Isn't it ?
Jean-Louis SCHRICKE
├ CTA - Certified TestStand Architect (2008 - 2022)
├ CTD - Certified TestStand Developer (2004 & 2007)
└ CLD - Certified LabVIEW Developer (2003 & 2005)
