Tiwi,
The blocking that InetTelnetRunScript does is probably there for a reason. That method is probably not safe for multiple threads to call into at the same time. There is likely another way to do what you are trying to do that can be done in parallel. Perhaps with lower-level telnet function calls. I recommend you post to the CVI forum asking if there is another way to do what you are trying to do from multiple threads in parallel. This does not sound like a teststand issue. If you are calling into your dll from multiple testand threads, then the code in your dll function is being executed in parallel. The cvi function you are calling however, might not be reentrant (reentrant means able to be called by multiple threads in parallel) so it is making one of your threads block until the other completes. I suspect there is a different way to do what you are trying to do that will not have this problem, but I think the changes that you will need to make will be in the dll and not on the teststand side. I recommend you post to the CVI group and explain what you are trying to accomplish and see if they have a solution for you.
Hope this helps,
-Doug
P.S. Each process on the Windows operating system (of which teststand is one) can only load one copy of any particular dll at a time. Also, loading multiple copies is not something that would be likely to solve the problem you are running into. One possibility is to use the call executable step type and create an executable that does what your dll function does, but that is probably not the best solution and might still end up blocking at the same location. The best solution is probably to use an alternate method of accomplishing whatever you are trying to do with the telnet function you are calling that does not have the limitations of that function.
