NI TestStand
Problem by Message Popup Teststand
Hello
sorry my English ist not perfekt:smiley sad:
 I have created an opportunity to make a choice of 5 elements on Message (Foto) so that when if you selected  Can1, only  Can1 be executed and to achieve this I have to go on Propreties-> Expression -> Post expression to write a condition where Locals.CanType declared is equals one of Buttons
in an example Teststand "computer6" I saw it on writing this expression at term Post Expression :
Locals.CPUType = ((Step.Result.ButtonHit == 2) "AMD": "INTEL") <<  this condition is valid for 2 buttons >>
The problem is: how can I write a condition on the Post valid expression for 5 buttons  ie that we must choose between the CanX, Can1, Can2, Can3 or Can4.
thank you in advance
Message 1 of 22
(5,479 Views)
What do you want to store in your local variable "CanType"?
Is it a string which reflects the label of the button?
I doubt that you need a case construct at all.
Possibly, something like "Locals.CanType = Evaluate("Step.Button"+Str(Step.Result.ButtonHit)+"Label")" could do the trick.
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 2 of 22
(5,468 Views)
Another simple option is to create an array with the possible values and then just index the value that was chosen with the button.
Locals.CanType = CanTypeArray[Step.Result.ButtonHit-1] //If the array is 0 based, you will need to subtract 1 from the ButtonHit result
GCentral
Message 3 of 22
(5,465 Views)
hello
Can_Type is a String und  i want to store the pressed button with him
Message 4 of 22
(5,455 Views)
hello
Can_Type is a String und  I want to store the pressed button with him.
I have used the first method but I get an error :
Systax Error:
Unexpected token : Step
I have already created Sequences eg CanxSequence, Can1Sequence and I would really like the calls with CallSequence , see below two picture.
Where can I create the Can_Typearray to use the second option
sorry for the question,I am a beginner in teststand
Message 5 of 22
(5,449 Views)
Just create a Local variable and populate it with the values you want.
GCentral
Message 6 of 22
(5,445 Views)
sonnyanderson wrote:[...]
Systax Error:
Obviously, there is an error in the expression. Are you sure that you placed the quotation marks (") correctly? You must not have quotation marks containing the whole expression, as this suppresses evaluation (as it is stated as a string!)
The expression is placed as POST expression of the MESSAGE POPUP step?
Norbert
Norbert
Expert: Geometry
Message 7 of 22
(5,437 Views)
Norbert
I JUST COPY PASTE THIS TIME CI, but STILL MY STEP RED
Message 8 of 22
(5,403 Views)
Yes, you miss-typed "step" as "setp" (red marked in the expression)......
Norbert
Norbert
Expert: Geometry
Message 9 of 22
(5,394 Views)
Norbert
there always wrong, but this time I'm typing
Message 10 of 22
(5,388 Views)
