11-01-2005 10:51 PM
11-02-2005 10:01 AM
Tony,
I just looked at TestStand 3.0, and the Sequence File Documentation Tool is listed for me. If your Tools menu is blank, go to the <TestStand 3.0>/cfg directory, and delete the ToolMenu.ini file. Restart TestStand. The file should be rebuilt for you with the default values, and your Tools menu should be restored.
Allen P.
NI
11-03-2005 02:26 PM
Allen,
This does not work for me. I looked for the ToolsMenu.ini as you suggested and did in fact find that it was 0KB with nothing inside. I deleted the file, ran from CVI which launched TestSTand and went directly into TestStand and each time the file created was the 0KB file. I ended up copying the file from another test development system using TestStand 3.0 and all is fine. Your thoughts on this problem?
Tony
11-04-2005 10:16 AM
11-04-2005 10:57 AM
11-04-2005 11:02 AM
Hi
I have attached the toolmenu.ini file.
Thank you
Anand Jain
11-04-2005 11:13 AM
