the described solution could be a workaround if there would be only one file to provide, but in my case
there should be a lot of files, because my expression is greated with two variables. One is set via an edit step
(specifies the filename) and the user one (specifies the directory) is set via PreStep execution of the Sequence Call.
I think it would be a nice feature of TS if only the SequenceFile to be executed should be on place and no
placeholders, even if they could be empty files!
Sunny
