Hi Rafi,
I was working from memory and I thought with the Goto step you could Terminate as well as goto Cleanup or End. Obviously memory not that hot.
Instead of using the last Goto step. Use a None Adapter with its Custom post action set to True and the True action control set to Terminate. Use the precondition on this step to invoke the step depending on whether the user pressed the Terminate button on your MessagePopup.
That should do the trick.
Regards
Ray Farmer
Regards
Ray Farmer
