I'm not a PERL expert, but I don't think there is anything in PERL that allows you to access ActiveX objects. Since you are writing a warpper that calls your PERL script (in some language that can access ActiveX objects), you could evaluate parameters (TestStand variables, etc...) in your wrapper, and pass it in the command line to PERL. For example, you could make a custom step type that had one parameter that was an expression for the arguments (perhaps using an expression edit control). You could store this property in a step property that is of type "expression". In your wrapper, you can call PropertyObject.EvaluateEx on your sequence context with the value of the expression as its parameter. Then you can pass this into the command line argument when calling your PERL script.
Allen P.
NI
