07-28-2006 08:48 AM
07-31-2006 11:05 AM
07-31-2006 12:28 PM
07-31-2006 01:47 PM
It all depends on where you want the text to show up. You can do custom step types with a bunch of string variables and write to those. You could do a custom step type with a cluster of a bunch of strings. You can definitely concatenate the string. You can append to it using the ActiveX VIs in the TestStand pallette. The simplest would be to concatenate it.
