10-18-2005 01:42 PM
TSDLL_API int32 TSTransfer(int32 hSystem, PIN_PARAMS_TRANSFERDATA pInData, POUT_PARAMS_TRANSFERDATA pOutData)
where the structure PIN_PARAMS_TRANSFERDATA is defined as
typedef struct
uInt16 u16Channel;
uInt32 u32Mode;
uInt32 u32Segment;
int64 i64StartAddress;
int64 i64Length;
void * pDataBuffer;
HANDLE *hNotifyEvent;
} IN_PARAMS_TRANSFERDATA, *PIN_PARAMS_TRANSFERDATA;
So,
How should the structure be represented in the Type gallery of TestStand??
How can I allocate a buffer (Array of Int8, or Int16 or Int32) and assigned it to the struct?
I would like to use a local variable that could be filled with the requested data so it could be used with further test.
Eric
10-19-2005 05:14 PM
10-20-2005 09:48 AM
10-20-2005 11:31 AM
10-20-2005 12:34 PM
10-20-2005 12:49 PM
10-21-2005 02:17 PM
10-24-2005 09:39 AM
