07-14-2005 08:54 AM
07-14-2005 10:16 AM
Bastina,
You could use a Station Global variable to keep the return parameter in that way the value will be available to all 4 sockets.
I am assuming that you set the Use Lock to Allow Only One Thread at a time to execute the step.
And that for Batch synchronization you selected the One Thread Only option.
In this case only one thread executes the step and the others threads skip it.
If you are keeping your return value in a local or sequence file global property the property will be available only to the socket that executed the step. (Every socket keeps its own run-time copy of these properties).
Best Regards.
05-03-2006 01:21 AM
