08-10-2006 02:57 AM
08-11-2006 10:09 AM
08-14-2006 12:20 AM
I have tried both. And it is the same. TestStand executes only one step at a time.
Schwede
08-14-2006 09:13 AM
I'm not a LV expert, but I think only one instance of a VI can run at a time unless you mark the VI as reentrant. So, you could make copies of your VI, or mark it as reentrant. I know that some (or all?) versions of LV can't debug reentrant VIs, so you might want to wait until the VI is debugged to do that.
(If LabVIEW now supports reentrant debugging, maybe somebody can mention the LV version number in which that feature was introduced?)
08-15-2006 12:19 AM
that is right, but I have tried to use two different vi`s with the same result. I think something is with the usb configuration (MAX?).+
08-15-2006 10:37 AM
08-15-2006 11:26 AM
08-16-2006 08:55 AM
