06-13-2006 07:41 AM
06-16-2006 04:29 AM - edited 06-16-2006 04:29 AM
Message Edited by NewOne on 06-16-2006 04:29 AM
06-16-2006 04:48 AM - edited 06-16-2006 04:48 AM
Hi NewOne,
You can do all this in the Type Palette window.
Right mouse click on a step type will give you an Edit Menu item ( not sure of the exact wording) to select. Once in this dialog window you will beable to reorder the menu items, by moving an item up or down or you can drag and drop.
You will also beable to create a new groups.
I think there is more information in the TestStand Help.
Hope this helps
Ray Farmer
Message Edited by Ray Farmer on 06-16-2006 10:49 AM
06-16-2006 04:58 AM
>Hope this helps
This is exactly what i was looking for.
>Ray Farmer
Thank you very much for this fast tipp.
06-20-2006 07:31 AM
Ray,
You'll have to start your own "Ray Nuggets".
Good tip indeed..
R-JLV
