08-22-2006 01:11 PM
08-23-2006 05:23 PM
Hello Guy04,
I don't see the same view that you are looking at. What version of Switch Executive are you using? If you are referring to routes that are all in one group, the switches will all close almost simultaneously, separated by a clock cycle of the FPGA. Is it important to you at this level what order they close in?
Laura
08-23-2006 08:09 PM - edited 08-23-2006 08:09 PM
Message Edited by Guy04 on 08-23-2006 08:09 PM
Message Edited by Guy04 on 08-23-2006 08:10 PM
08-25-2006 07:13 AM - edited 08-25-2006 07:13 AM
Hello Guy04,
It seems that order can't be determined. Please see this section from the NI Switches Help:
I think the best solution is to call the routes in different steps, like you mentioned.
Laura
Message Edited by Laura F. on 08-25-2006 07:14 AM
09-06-2006 09:46 AM
Guy04 -
If you do not want to use the switching tab, you can use the switching expression functions separated by a comma, ex.
SwitchConnect("device", route1), SwitchConnect("device", route2),...
This way the TestStand will execute each call in the order that they appear in the expression.
