I’m currently in the process of modifying the TestStand 3.5 CVI Operator Interface (using CVI 8.0.1).
At the end of the execution I would like to copy the created Test Report from the system on which it was generated to another system on the network.I’ve wrote a routine to do this which requires the report filename. Is it possible using the TestStand API functions provided to get the filename of the report that has just been created?
