06-06-2014 02:31 AM
Yesterday I was working on a sequence and wanted to get data from another: I've opened the second one in addition to the first one (another tab was created).
I've checked my data, I've worked as I wanted.
I probably closed TestStand sewEdit with both sequences opened.
This morning I want to open my sequence and it is corrupted: I can't work on what I did yesterday.
I've reopened an old copy and will reimplement the changes I remember.
Attached the screen copy of the error message.
A colleague of mine tells me such errror is common from long time, he already detected it in V3.1...
06-06-2014 11:15 AM
Are you perhaps editing variables or types programmatically? %EPTYPE is used by the ini format for storing the array element prototype of an array of containers/typeinstances. You shouldn't get an error like this with the kinds of edits that can be made in the sequence editor, though it could perhaps happen if a programmatic edit was made in an unsupported/unexpected way.
Either way, if you can give us enough information to reproduce the problem, we can hopefully determine the cause.
-Doug
