NI TestStand
Open LV front panel of a failing step?
If a step fails i want to show the LV front panel so the "tester" can see all controls/indicators to get more info about what went wrong.
new at TestStand so this might be basic stuff but i havent found a solution.
/J
(3,531 Views)
Accepted by topic author std
What is basic about TestStand that you should understand is that the evaluation of a step is done after the step executes and the VI is closed. You obviously can't show the front panel at that point. You could add a post step fail callback to rerun the step and where you tell it to show its front panel. Additional modification of the VI would be necessary to place it in a paused state.
(3,515 Views)
