You maybe able to setup the report filter to this, but I think the options are "All", "Failed" and "Skipped/Passed/Done" to exclude from the results. ( I dont have TestStand at hand at the moment but can confirm this later if someone else hasn't done so)
If this is the case, then your options are:
1. To modify the reportgen_[xml | html | txt].seq, the sequence you would be looking to change would be the "PutResultsInReport". If you are using XML generated results, it maybe be possible to modify the schema rather than change the sequencefile. (Not sure about this)
2. Remove the SequenceCall results from the Locals.ResultsList in MainSequence, problem in the Cleanup before you exit MainSequence.
I hope this helps
Ray Farmer
Ray Farmer
