04-28-2006 03:58 PM
04-29-2006 04:06 PM
Hi Grasshopper,
Your TestReport.seq, the contains of the MainSequence is this the same as the contains of the TestReport sequence in SequentialModel.seq.
If it not, then you need to sure the changes required for on the fly reporting are carried out to the TestReport sequence in SequentialModel.seq or are in the Override callback TestReport sequence in your test sequence file.
Ray Farmer
