09-25-2015 09:06 AM - edited 09-25-2015 09:17 AM
If a step using the Adapter: Sequence, uses the Type: NumericLimitTest, its results are not logged to the database in the same manner as a step that uses the Adapters: LabVIEW or <None> (other adapters may fall in this bin but these are the only others I use). This forces data associated with NumericLimitTest to be retrieved in different manners, duplicating the effort of data analysis tools.
Log measurement results in the following manner:
Measurement information is stored in an explicit column for its type (high low limit, compare operator) this is the desired method for ease of data retrieval and analysis.
DB Table [PROP_RESULT] (Stores measurement name and measurement value)
ORDER_NUMBER |
NAME |
PATH |
CATEGORY |
TYPE_VALUE |
TYPE_NAME |
DISPLAY_FORMAT |
DATA |
0 |
Numeric |
Numeric |
2 |
0 |
NumericLimitTest |
0 |
DB Table [PROP_NUMERICLIMIT] (Stores limit test specific information)
COMP_OPERATOR |
HIGH_LIMIT |
LOW_LIMIT |
UNITS |
STATUS |
GELE |
11 |
9 |
NULL |
Failed |
All step information is logged to the [PROP_RESULT] table in an Entity Attribute Value model format. (Difficult to work with from a SQL retrieval perspective)
DB Table [PROP_RESULT] (Stores data a measurement name, measurement value, measurement attribute(s) name and attribute(s) values)
ORDER_NUMBER |
NAME |
PATH |
CATEGORY |
TYPE_VALUE |
TYPE_NAME |
DISPLAY_FORMAT |
DATA |
1 |
Numeric |
Numeric |
2 |
3 |
Number |
%#.2f |
14.95969 |
2 |
Units |
Units |
2 |
1 |
String |
NULL |
V |
3 |
Limits |
Limits |
2 |
0 |
Container |
NULL |
NULL |
4 |
Low |
Limits.Low |
2 |
3 |
Number |
%#.2f |
14 |
5 |
High |
Limits.High |
2 |
3 |
Number |
%#.2f |
16 |
6 |
Comp |
Comp |
2 |
1 |
String |
NULL |
GELE |
To be able to use steps with the adapter: Sequence of type: NumericLimitTest that log data in the same format as described in part 2.1 of this document.
The following workaround could be used but an alternative is desired so that this could be corrected at the test station level so that existing sequence file would not have to be individually updated and validated.
Use only steps of adapter: Sequence of type: SequenceCall and pass values from sequence call to steps of an adapter: <None> of type: NumericLimitTest for evaluation and logging of the measurement.
09-28-2015 09:24 AM
I think I figured this one out.
In Database Options window on the Statements Tab there is a Traversing Options. On the Traversing Options for the STEP_SEQCALL statement the “Skip Remaining Steps Result Statement for this Step” was checked, this seems to be the default for all the default schemas except “SQL Server Stored Proc (NI).” Unchecking this option resulted in the results being stored in the same fashion as the other NumericLimitTest using other adaptors.
This doesn’t seem to have had any negative consequences as far as how other results from steps that use the sequence adaptor act. Although, it would be nice for if a NI Eng could reflect on why this option is selected by default and if they see any consequences to deselecting this option.
