03-19-2015 09:53 AM
Hello !
I am quite new to Teststand and I get stuck with an issue of which the solution should not be that intricate ... (I think ...).
I would like to use a "Numeric Limit Test" vi (LabVIEW module). This vi returns 3 arrays and I would like to define 1 "min/max" set for each array.
i.e. :
ARRAY1 => each element compared to min1 & max1
ARRAY2 => each element compared to min2 & max2
ARRAY3 => each element compared to min3 & max3
For 1 array, I found this solution : I write Locals.ARRAY1[RunState.LoopIndex] in "DataSource" and all the elements of the array are compared to the limits I have chosen. Of course, when I add 2 arrays, the same limits are compared to those new arrays but I would like to allocate 1 limits set to 1 array.
Does anyone have an idea of an easy solution ?
My Teststand code and the little vi are here below if it might help.
Thank you in advance !
03-19-2015 10:25 AM
Consider this example. The trick is Repeat One Measurement on the Data Source tab.
03-19-2015 10:35 AM
Damn ! It seems so easy the way you have solved this ! I definitely like this solution and you answered my next question ("How can I get to know which element of the array was not in the limits?") at the same time !
Thank you !
03-19-2015 10:44 AM - edited 03-19-2015 10:45 AM
