NI TestStand
Notification from LabVIEW to TestStand
I'm trying to send notification form LabVIEW to TestStand.
The idea is to break while loop from Operator Interface, during waiting for temperature chamber setpoint, when operator clicks some button.
As you can see above, I have a while loop (normaly stop condition is temperature setpoint from temperature chamber). When operator click "break loop" on the OI then "Break step" precondition flag is changed (station global variable) and it should also send notification to "Wait step".
Unfortunately I don't know how to send this notifier form LabVIEW based OI. I hoped that if I will store notifier reference in FGV, then I will be able to use it in my subVI which you can see below.
This way I'm getting Error 1 "Incorrect function"...
Any suggestion how to do this loop breaker?
Michał Bieńkowski
CLA, CTA
Someone devote his time to help solve your problem? Appreciate it and give kudos. Problem solved? Accept as a solution so that others can find it faster in the future.
Make a contribution to the development of TestStand - vote on TestStand Idea Exchange.
(3,415 Views)
Michal,
the easy way to solve that specific use case is to keep the terminate button on the UI.
However, if you want to go into direct communication, please reference the "User Instructions" example of these demo implementations.
Norbert
Expert: Geometry
(3,347 Views)
If you store the notifier reference in an FGV, you will need to be aware of what application instance you're giving the reference to. You also need to make sure the reference is valid at the time you read it out of the FGV.
A better option might be to call GetSyncManager somewhere in your LabVIEW code.
This is something I'm actively trying to create better examples of, so let me know if there's anything in particular that's unclear.
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
(3,340 Views)
So is it possible to get some handler for my notifier in TS with GetSyncManager?
Michał Bieńkowski
CLA, CTA
(3,326 Views)
Indeed. That is part of the linked example(s) of my previous post.
Norbert
Expert: Geometry
(3,321 Views)
