02-16-2006 09:09 AM
02-16-2006 04:15 PM
How big?
Are the subSequences in seperate sequence files?
What TestStand version are you using?
Ray Farmer
02-17-2006 01:43 AM
Hello Ray,
1)
I had two string arrays with: array1[0....11][0...800], array2[0...6][0.....400]
until this everything was ok
then I increased the array1 to array1[0....11][0...1200]
from this point I had the problem
2)
No the subsequences are in the same sequence file
3)
I am using teststand 3.1
would it be better for this probelm to use teststand 3.5?
Thank You for your help
regards
Samuel
02-17-2006 09:03 AM
Samuel,
How are you accessing the FileGobals, is via the expression step or an TS API GetVal method.
Ray Farmer
02-17-2006 09:49 AM
hello ray,
everithing is ok now...i have solved the problem
thank you for your help
regards samuel
02-17-2006 03:07 PM
02-18-2006 03:42 AM
Ray,
yes of course I share the information.
I double clicked on the sequence calls, then I clicked on "specify Module". There I enabled the clickbox "Use current File"
From this point I had again access on the fileglobals in the subroutines
regards
samuel
