NI TestStand
Need shortcut
Hi all,
I have sequence which contains 100+ Ex: Subsequence 1, Subsequence 2,,,,, Subsequence 100
if i want to remove any step means I have to remove in all subsequence
Are there any way like if I can remove all at a time( instead of go to each subsequence and delete a step)
Thanks in advance
(3,243 Views)
I don't think there's a way to do that.  Given the commonality in your subsequences, there's probably a better way to architect your sequence files and perhaps your model.
Pulido Technologies LLC
(3,209 Views)
There is no direct way.
Have written a small test sequence which does that.
Run the MasterSequence.seq which removes statement1 step from
sequenceUnderTest.seq
Few changes that you may need to do :
MasterSequence.seq
Edit locals.StepToBeDeleted and locals.Filepath.
Hope this helps.
Ravi
(3,136 Views)
