02-05-2016 06:43 AM
Hi All,
I am getting an error while logging, I think I have changed something in directory so it is asking x64\frontend.dll file i could not find it anywhere.
I found frontend.dll for 32 bit but not for 64bit.
I also tried uninstalling teststand 2014 and installing it again. Same problem i have facing
Need Suggestions
02-05-2016 08:40 AM
Do you perhaps have a custom version of FrontEndCallbacks.seq in your public directory? If so, perhaps that is where it is not finding the 64-bit version. You should be able to copy it from the installed location at C:\Program Files\National Instruments\TestStand 2014\Components\Callbacks\FrontEnd to whereever your custom version is in your public directory. Or delete your custom FrontEndCallbacks.seq if you aren't using it.
Hope this helps,
-Doug
02-05-2016 11:32 AM
Thanks a lot Dug
