I downloaded the toolkit to try off the web but the toolkit is not compatible wioth Teststand 2014. What is the solution for TestStand 2014 for an ATML toolkit or am I missing something?
Thank you for inquiring. You are correct that the TestStand ATML Toolkit 2013 is not compatible with TestStand 2014. Unfortunately, we do not currently have an ATML toolkit that is compatible with TestStand 2014. If you would like to use the toolkit, you will need TestStand 2013.
We have published a KnowledgeBase article that addresses NI TestStand ATML Toolkit support for TestStand 2014. Please have a look at the KB to address your question.
