NI TestStand
NI Test Integration Adapter report file in RQM with broken links
I'm using NI test Integration Adapter v2.3 to connect IBM RQM v6.0.1 and TestStand 2014. I execute the corresponding secuence file and the generated report (html file) is uploaded to RQM in TestStand report pane. This report contains some links to local files but they're broken. Is there any way to use the adapter or configure TestStand to upload the local files as attachments and use those links in the Test Result page instead of links from the HTML report?
Thanks in advance,
Rakel
Message 1 of 1
(2,959 Views)
