I have a test PC previously installed NI USB 6008 driver with a 6008 logger (lets say its logger A), my question is , can I use another NI usb 6008 logger (logger B) on this same PC? does the PC or driver recognize its not the same logger?
Yes. You can use another USB-6008 on that computer. The PC will recognize that it's the same logger. In MAX, you will also be able to tell that logger B shows up with a different serial number than logger A.
the reason I asked this is because a problem I have with the USB 6008 recently: I have a test using USB6008 to measure voltage and frequency, it was working fine until I switched logger A to logger B, the device cannot measure voltage but has no problem measuring frequency , both USB 6008 are good and working fine before. Do you have any idea why this is happening?
