Hello, I have a question regarding a test application that must be run in Testand 3.0, I have to test 6 UUT, each is connected on a serial port of a NI PCI232/8 multiport card (Card driver is NI Serial 1.7).
To start I created a DLL (with CVI 7.0), that manages the communication functions like Open & Close Port, sending commands and receiving answers to / from UUT etc. I made a sequence file that call functions inside the DLL, using Sequential Model and tested the application on one UUT, everything seems to be OK.
Now I would like to increase the number of UUT's that I controll, and to use Parallel Model. I am not very familiar with this model and my question is if the DLL that I created to manage the communication functions, must be changed or it can be used and it is. When creating the DLL I didn't employ any thread safe functions or thread safe variable access methods. Will Testand take care of this issues when using the parallel model ?
Below is a part of the code that implements main functions in the communication DLL.
Any comments or examples about using serial port communication in a multithreaded application manged by Testand would be greatly appreciated.
Regards
int InitUIForDLL (void);
void DiscardUIObjectsForDLL (void);
int __stdcall DllMain (HINSTANCE hinstDLL, DWORD fdwReason, LPVOID lpvReserved)
switch (fdwReason)
case DLL_PROCESS_ATTACH:
if (InitCVIRTE (hinstDLL, 0, 0) == 0)
return 0; /* out of memory */
break;
case DLL_PROCESS_DETACH:
if (!CVIRTEHasBeenDetached()) /* Do not call CVI functions if cvirte.dll has already been detached. */
CloseCVIRTE ();
break;
return 1;
int __stdcall DllEntryPoint (HINSTANCE hinstDLL, DWORD fdwReason, LPVOID lpvReserved)
/* Included for compatibility with Borland */
return DllMain (hinstDLL, fdwReason, lpvReserved);
int _VI_FUNC OpenConfigPort (int COMPort, long baudRate, char parity,char deviceName[], int databits, int stopBits,int inputQueueSize, int outputQueueSize)
int retVal;
OpenComConfig (COMPort,"", baudRate, parity, databits, stopBits, inputQueueSize, outputQueueSize);
if ((retVal = ReturnRS232Err ())!=0) return(-1);
comPort = COMPort;
FlushInQ(comPort);
FlushOutQ(comPort);
return(0);
int _VI_FUNC ClosePort (int COMPort)
CloseCom(COMPort);
FWT_Connect=0;
return(0);
int _VI_FUNC sendcmdNoParam (int comPort, int *errorCode, char classID, char CommandID)
unsigned char Command[10];
char InBuffer[16384];
char InQ,OutQ;
unsigned char i;
unsigned char ChkSum;
FlushInQ(comPort);
memset (InBuffer, 0, strlen(InBuffer));
Command[0] =
Command[2] = ClassId;
Command[3] = CommandID;
Command[5] = ChkSum;
OutQ = ComWrt (comPort, Command, 6);
while((OutQ = GetOutQLen(comPort))!=0);
InQ = GetInQLen (comPort);
ComRd(comPort,InBuffer,InQ);
ChkSum=0;
for(i=0;i<strlen(InBuffer);i++) ChkSum+=InBuffer[i];
if(ChkSum) return(-1); //CheckSum Fail
return(0);
