I am using TestStand ActiveX/COM step types to call methods on COM interfaces. Unfortunately the method parameters are not always named well, and our customers get confused. I was hoping there was a way to effect the parameter name that appears in the 'Edit ActiveX/COM' dialog parameter editor, without actually changing the interface. I was hopeful that changing the parameter name stored in the sequence file (Step.SData.Call.Paramaters.[XXX].Name) would affect what appears in the dialog, but no such luck. Any ideas?
Does the parameter name do anything? What about the parameter 'DisplayType'? Changing that also does not affect what appears in the 'Edit ActiveX/COM' dialog.
I am attaching some screen shots for clarity.
Aaron Stibich
Innovative Technologies Inc.
