11-14-2005 12:58 PM
Begin Sequence: MainSequence
(Unsaved Sequence File)
Message Popup: Failed
Button Index: 0
End Sequence: MainSequence
End UUT Report
I want to remove the text in italics. I have removed this one by editing AddSequenceResultToReport sequence, when I didn't used the on-the-fly option. But now the tags with on-the-fly option were inrtoduced by "Process Step Result" step of "ProcessOTFStepResult" sequence. And my sequence stack is upto 5 sub sequences. So when a step fails, it report prints 5 sets of begin and end tags, which I wan to avoid. Any help???
mama007
11-14-2005 03:06 PM
You need to modify the InitializeOFT sequence found in the reportgen_html.seq or reportgen_txt.seq. You will see two steps. One the template for the Sequence Header and the other for the Sequence Footer.
For example:
Locals
.SequenceHeaderTemplate = "<H5>" + ResStr("MODEL", "RPT_BEGIN_SEQUENCE") + "%Sequence%\n<BR>(%SequenceFile%)<BR></H5>\n"The SequenceHeaderTemplate is a string built up to create "Begin Sequence: MainSequence". You probably can spot the various parts.
Hope this helps.
Ray Farmer
11-16-2005 06:30 AM - edited 11-16-2005 06:30 AM
Message Edité par Aurelien_R le 11-16-2005 06:37 AM
