I've attached an example of a TestStand 3.1 sequence that creates a step type called "PSU1" and saves it in a type palette file called Instrument.ini. This works fine and creates the step type OK. However, I'd like to have the ability to modify some of the properties of the step type after it is created. If I try to re-run this sequence with some of the step type's properties modified I get the message: "An error occurred calling 'InsertType' in 'TypeUsageList' of 'NI TestStand API 3.1'. The item name 'PSU1' is invalid because it is already in use."
I realise that this occurs because the type name is now in memory. Is there a way of being able to remove the step type from memory, then re-add it again? I've tried using the TypeUserList.RemoveType method but have been unsuccessful in obtaining an index to the type within the PropertyObject I am using.
Alternatively, removing the Instrument.ini file would work for me, as I would like to create one of these when I launch TestStand based on the instrument's intalled on my PC. I haven't found a way of removing this apart from launching the TypePalette editor and manually deleting the step type, or removing Instrument.Ini from the PC.
David
