NI TestStand
Modifying ListBar item in LabVIEW Operator Interface
In the LabVIEW full featured Operator Interface for TestStand 3.1 I'd like to change the functionality of the "Close Sequence File" in the Files Page of the ListBar.
I figured out how to change the File Menu "Close Sequence File" in the "Main Even Loop" of top level VI. I haven't found where the ListBar event is detected so I can add to the functionality. I've looked at the VI's that setup the menus in the pages, but haven't found were the items are executed when selected.
Any help would be appreciated.
(2,903 Views)
The Listbar event is called before the Main event loop. It is located in the Configure Event Callbacks vi with the name Listbar Create Context Menu.
Jon M
Test Engineer - CTA
(2,886 Views)
Thank you. I changed the "Sequence Close" in the menu to "Close All Sequence Files and Executions" to accomplish what I needed to do.
(2,866 Views)
